Diode Vs Motherboard Readings
myself and a friend were talking about our watercooling rigs and we compared temps.
His rig:
Diode - 37c
Block - 29c
My Rig:
Diode - 24c
Block - 35c
I then said that his setup looks odd as his diode is far higher than his block temps and generally in solid watercooling setups it should be the other way around due to no air flow around the motherboards CPU temp probe.
I don't really have solid info to prove this so i was wondering if anyone could breifly explain if i'm correct and why the above affect happens, ie, the diode is usually lower then the heatsink temp probe due to a lack of airflow around the waterblock.
I'm sure i've seen loads of thread about this...
Cheers dudes.
