My christmas snow, with new evap hose.
Made my own snow for christmas :D,
Testing new evap hose on knocked up single stage (this with 120 watt resistive heat load)
http://www.coolmods.com/whiteice/evap-hose-test1.jpg
~50 watt (uninsulated) load:
http://www.coolmods.com/whiteice/evap-hose-test2.jpg
Damn good hoses these, from bes ltd: http://www.bes.ltd.uk/nav_graf/frames_cat.htm
Product 14878 1/2" x 1/2" TM x 600 mm fan coil assembly (this is the 450mm one)
Only £5 postage (or free if ya spend over ~£40)
Just cut off the BSP connectors, fit in 3/8" copper couplings into the remaining holes (near perfect fit) and silver braze with some flux..done this with mapp torch, easy enuf with 40% silver rods..they're proper corrugated stainless steel hoses, with stainless steel outer brade. 1/2" diameter is smallest they do, but thats great for good suction line vac pressure, its improved temps by over 10c under load with my ol NL11F prommy comp setup.
Ideal for ppl in the UK, as they know its hard to get hold of stainless steel hoses here.
