Shreader to Propane Bottle Guide
Today I made a simple shreader to propane bottle conversion valve. I thought, maybe some people want to see how I made it.
This conversion pipe is made because many people (including me) uses propane as a refridgerant. I couldn't find a conversion pipe from propane to shreader so I made one. Because there weren't any guides on the forum, I made some pictures and a discription of how to make one.
First of all, we need a connector. I used a connector from a propane hose. This can be bought at practicaly any supply store that sells torches (for dutch and german people: Horn bach is the store to look at).
http://members.home.nl/epsilon/phase...p/verloop1.jpg
Saw it off
http://members.home.nl/epsilon/phase...p/verloop2.jpg
The parts. A gas nut (turning left to tight them) from the hose, a shreader valve on a 6mm pipe and the coupling that I sawed from the hose.
http://members.home.nl/epsilon/phase...p/verloop3.jpg
The hole in the coupling was around 4mm. So I had to drill a bigger hole in it. I did not drill entirely trough the coupling but left 2mm.
http://members.home.nl/epsilon/phase...p/verloop4.jpg
How it should be put together
http://members.home.nl/epsilon/phase...p/verloop5.jpg
This is how it will fit on the propane bottle (now unbrazed)
http://members.home.nl/epsilon/phase...p/verloop6.jpg
The coupling brazed onto the shrader valve.
http://members.home.nl/epsilon/phase...p/verloop7.jpg
Detail shot. The coupling is brazed with 40% silver + flux around the rod because the coupling itself is steel.
http://members.home.nl/epsilon/phase...p/verloop8.jpg
The completed Shreader to propane bottle conversion valve.
http://members.home.nl/epsilon/phase...p/verloop9.jpg
I hope this is a usefull guide :D
It is quite simple to make, but there aren't any guides on XS :).
Good luck ;)
