K8N Neo2 Platinum install problems
Hey guys - just got my new Neo2 Platinum board and my Athlon 64 FX55 in. Unfortunately - its not working to my liking. I hooked everything up properly, installed my vapochill and had everything connected. I turned it on, vapochill powered up, began to cool to the negatives. At -10c computer turns on to nothing but 2 second beeps every 2 seconds. So, i turn it off, figuring it may be the memory, take it out of CHB and put it in CHA. Turn it on, works fine. I get into the bios and it sees 1gig of ram, yet only recognizes single channel and says its at 133mhz and at extremely loose timings. The memory i have is G.Skill PC4400 rated at 2-2-2-5 at PC3200 and 2.5-3-3-7 at PC4400. Samsung TCCD chips - i've seen many reviews with this board and it has worked perfectly. Either way, i went to try and lower the timings and it rebooted and got nothing but beeps again. So i turn it off, attempted to reset CMOS - and turned it on. Vapochill cools to -10, then tries to turn on the rest of hte computer. At that stage, it can't turn the rest of the computer on. I tried even unplugging power from the vapochill and hooking up the mobo as if it were a regularly cooled computer - no boot. I then tried to jump the PSU to make sure i didn't blow it - it turned on. Its an OCZ PowerStream 520W and the green light came on and fans were spinning. So right now i'm stuck in the mud and i'm really anxious to get this rig up and running. Please let me know what to do!! Thanks!
