There IS a way to mod all these unmoddeble X800!!!
Hello guys!
A very good Polish overclocker/modder- "Lancer", described over @ Twojepc.pl a way of flashing a X800PRO Sapphire (the XT one) to a XT!!!
Ill translate the whole article for you guys later, now ill give you a short description:
1. Downlowad the ATI Flasher
2. Download the Gigabyte X800XT PCI-X bios
3. Flash
4. Check if everything works
5. If there are any artifacts reflash to a standart XT bios and reset all your tweaking programs- everything should work now
Lancer belives that the PCI-E bios overrites some data in the EEPROM wich are there for the missing texture units, overitting with different data causes them to start working. Normal ATI biosed dont do it (leave some parts of data untouched) not unlocking bioses!
berkut
