Abit Modded Bios's updated
WARNING! MODDED BIOS'S. USE AT YOUR OWN RISK, AMDFORUMS/MEMBERS WILL NOT BE HELD RESPONSIBLE FOR ANY DEAD BOARDS OR CORRUPTED BIOS'S. DONT FLASH THESE BIOS'S IF YOU DONT HAVE A BIOS SAVIOR OF SOME SORT. THESE BIOS'S ARE BETAS AND SHOULD BE TREATED THAT WAY!!!!!!!!!!!!
Tictac Bios's
D23 SUB-ZER0
Features:
- Base on D23 bios
- ROMSIP Table Modified (High Performance FSB on every multiplier)
- SATA Bios Version:
a)SATA 4247
http://downloads.modlabs.net/bios/b...UBZER0-4247.zip
b)SATA 4227
http://downloads.modlabs.net/bios/b...UBZER0-4227.zip
D22-Alpha1.zip with multiplier fix
http://home.comcast.net/~shrmytoon/D22-Alpha1.zip
D22-alpha beta king with multiplier fix
http://home.comcast.net/~shrmytoon/d22a1bk-4227.zip
D22-alpha beta turbo w/ sata 4227
http://home.comcast.net/~shrmytoon/d...turbo-4227.zip
D22-alpha beta turbo w/ sata 4247
http://home.comcast.net/~shrmytoon/d...turbo-4247.zip
d10beta4
http://home.comcast.net/~shrmytoon/NF7D_10b4.ace
d10beta1
http://home.comcast.net/~shrmytoon/NF7D_10b1.ace
d10beta2
http://home.comcast.net/~shrmytoon/NF7D_10b2.ace
Tictac D22-3DFire
http://home.comcast.net/~shrmytoon/D22-3dfire.zip
Tictac D22BetaKing
http://home.comcast.net/~shrmytoon/NF7D_22BetaKing.zip
d14beta-beta2
http://home.comcast.net/~shrmytoon/n...beta-beta2.rar
D10 Beta 2 R2
Change Log:
- Update BPL from version 2.91 to version 3.19
http://home.doramail.com/tictac/D10-beta2-R2-4247.zip
D10 Beta 4 R2
Change Log:
http://home.doramail.com/tictac/D10-beta4-R2-4247.zip
D23 subzero R2
Change Log:
- Update BPL from version 3.02 to version 3.19
http://home.doramail.com/tictac/D23-subzero-R2-4247.zip
http://home.comcast.net/~shrmytoon/D...ro-R2-4247.zip
D23 3d fire R2
Change Log:
http://home.doramail.com/tictac/D23-3d-R2-4247.zip
-=PR3ACH3R=- Bios's
no direct links aloud at this time but you can get them at his site
http://pr3ach3r.overkillsystems.net/
Trats Bios's
cheers to shroomy and abducted for hosting the files
for us to download: you guys are really great
:thumb:. thanks to everyone who tested the bioses :D.
most importantly, many thanks to tictac for his
bios modding work, and for his posts
here
and
here,
showing us how to mod nf7 bioses.
the bioses tested ok, but use them at your own risk
d24 revision 1, thanks shroomy for linking them for
us :thumb:
- romsip mod
- revision 1
d24
r1 sata 4227
d24
r1 sata 4247
d24 revision 2
- romsip re-tuned
d24
v2 sata 4227
d24
v2 sata 4247
d24 sub-zero
- romsip-mods, using tictac's sub-zero codes,
d24
sub-zero sata 4227
d24
sub-zero sata 4247
d24 3d lite
- based on tictac's d23 3d where romsip table was
fine-tuned to d10
- similar to v2 and sub-zero above, but 3d has more
d10 codes
- classical layout, hence the lite version
d24
3d lite 4227
d24
3d lite 4247
d24 with d10-bpl mod, thanks Abducted for linking
the files :thumb:
- romsip mod
- d10-bpl mod
- the main difference between 3d and v2 is that 3d
has more d10 codes modded into it, following tictac's
3d d22 and d23
d24
3d 4227 d10-bpl
d24
v2 4227 d10-bpl
d10 bpl mods
original d10 modded with:
- 4227 sata
- either d11-bpl, d14-bpl or d24-bpl
d10
sata 4227 with d11-bpl
d10
sata 4227 with d14-bpl
d10
sata 4227 with d24-bpl
more d10 bioses with different bpl
d10
sata 4227 294-bpl
d10
sata 4227 309-bpl
d10
sata 4227 317-bpl
tictac's
d10 b4 sata 4247 with d24-bpl cheers tictac :D
d24 3d sata 4227 with different bpl
d24
3d sata 4227 with d11-bpl
d24
3d sata 4227 with d14-bpl
d24
3d sata 4227 with 319bpl
d24 3d sata 4227 with different romsip tables from
an7 alpha 3 bios and different bpl
thanks tictac for the an7 bios :D
d24
3d sata 4227 with romsip tables 4-6 from an7 alpha 3
bios
d24
bios and d14-bpl
d24
3d sata 4227 with romsip tables 5-6 from an7 alpha 3
bios
d24
bios and d14-bpl
added 5/22/04...
some new d24 bioses. modified the sip tables a bit, and also used a table from infinity. these d24s gave no performance hit when bios cpu interface was disabled.
the same fsb oc with prime. 3dmark stability was better when cpu interface was disabled in bios but not at the expense of bandwidth. the sandra scores and prime benchmarks were not affected by bios cpu interface setting. the 1st bios gave better sandra scores than the other w/ infinity sip table
d24 sata 4227 revision 3 with ED table mod
d24 sata 4227 revision 3 with infinity ED table mod
Here are some threads for info on the bios's
Tictac modded NF7 bios's, now with mutliplier fix.....
http://forums.pcper.com/showthread.php?t=287064
Trats Modded Bios - ROMSIP & BPL mod
http://forums.pcper.com/showthread.php?t=321763
D23 Sub-zer0 : Online
http://forums.pcper.com/showthread.php?t=311230
I Officially Retired from bios modding job...
http://forums.pcper.com/showthread.php?t=319805
HARDM3NU Bios for the NF7S v.2.0 - UPDATED
http://forums.pcper.com/showthread.php?t=302118
