Hello...:D
Could you tell me what testorder you run in 3D01 plz :toast:
I have been running all kinds of ways i find
unrealneo's way is fastest so far
CH
LH
DL
DH
LL
N
CL
Thanks for your time and i will pass on my findings:comp10:
Hello...:D
CH
LH
DL
DH
LL
N
CL
I like to run nature first and high details after.
The first test you run will run at its best.
No joy with nature first :(
If i dont run car high first i only get CH>100fps but run first its 107:eek:
Anybody want to share their secrets:D
Nature doesn't see a big boost like the other tests do.
I recommend Drago Low first.
stestan you sure you're only getting 108fps in Car High with the specs in your sig?
Mine will get ~103fps and my system should be way slower than yours.
EDIT I just realized you have slower memory timings (mine were 2-3-2-5 though).
No m8 thats running
2.8c @ 250fsb
mem @ 5-4-3-2
raddy @ stock pro clocks
Alright I just figured you meant at 283fsb, that would be way higher.
Card clocks don't matter though.
:confused: I would of thought that more people benched 3D01 in diff test orders:stick:
CH>CL>N>LH>LL>DH>DL. My system really needs to get the car chases out of the way first it seems.
I always run nature first when I am at my cpu and cards limits.
nat
drg hi
drg lo
lobb hi
lobb lo
Car hi
car lo.......car lo........car lo........car lo........until I get the best score that bug in car lo will give me :)
I've been doing CL-DL-LL-DH-CH-LH-N ...
Nature is the least FSB picky so I try to get the others done first while it's stable :) Usually run CL a couple times to begin with...then continue on.
i know people say if you run some of them again, you can get a better score.
i have never gotten a better score on something unless i increased video card clock speeds...
i run the highs, then lows, then nature.
I run LL, DL, CH, LH, DH, N, CL until I get a good score. Works great for me. If you run CL enough you'll get a high score on it. Also I notice that some test give bigger increases if put in front
This is pretty close to mine. Lows first is faster than highs first by a good 200 points for me.Quote:
yes, but remember, if you get a 5fps increase in a high test, you would need a 10fps increase in a low test to give the same ammount of extra points... ;)
Heres mine:
DL
LL
CL
DH
CH
LH
N
I have found if you run Lobby High before Car High, your CH fps will suffter a lot. For me it was like 85fps vs 93fps on my 5950 depending where I put it into the order. Thats a 160 point loss.
I run DL first since it gives the biggest boost. I also tried doing highs first but it was about 200 marks slower.
This is true and I tried it that way, but for me I get a bigger increase (points) in the LL, DL if I run them first then if I run the high test first and not as big a drop in score if I run them later on.Quote:
DL
LL
CL
N
DH
CH
LH
then rerun Car Low until you get a good one
works for me anyway
i run mines
cl
ch
dl
dh
ll
lh
n
it's weird my best run is when i run the benhcmark right right after first cold boot. afterwards, the scores go down after each bench by 200pts!
DL
LL
CH
DH
LH
N
CL
OPP:D
Well, hard to argue with the man at the top. I just wanted to add a little bit of logic for running Nature next to last and CL last. Nature seems to care very little when its run so why let it slow down the other test. CL, if you run it enough times will give you a good score regardless of when you run it, so why let it slow down the rest of the test and just run it last.
Exactly:)Quote:
OPP
yes but Lobby loves to be ran first:D
Yes but then the Drago takes such a big hit, plus it uses up the vidcard initial cooling, and being that Drago is a Vidcard test you want the card running fast as possable and you need that extra coolness:DQuote:
It would be nice to run all the tests First:D
OPP
Opp,
Whatcha' doin?? Now that you told the secret EVERYONE can grab 30K ;)
C
Sure if they can match OPP's CPU, memory and video card clocks and all the other tweaks :)Quote:
Originally posted by charlie
Opp,
C
Gotta try OPP's order on my Ti4200 and see how it compares ... my drag low was suffering, could be just what the doctor ordered :D
