I've seen vMods articles linked on these forums - LOTS of them - for regular 9800s and 9800 Pros.
I've also seen a vMod article on a 9800SE AIW. Close, but not quite.
Anyone vMod an all-in-wonder 9800 Pro and post a guide on it?
Hi guys!
I'm also interested!:)
I think if you feed it to many volts the TV tuner box gets pissy...
I find it difficult to believe the TV tuner box would be tied into the voltage for the core or the memory. I'm sure it does have a voltage regulator, but I am really *not* interested in over-volting the TV tuner box.
Or, probably, not the vddq or half a dozen other voltage points on the card.
Only interested in the vGPU and vMem.
Honestly, I don't think it's that hard to do...the voltage regular chips for the core and mem are typically pretty obvious.
The voltage *read* points I'm more curious about. Especially because using the caps to do it is VERY DIFFICULT on these cards do to the placement of the caps in relation to the TV tuner 'box'.
Here is the card in question with the vMod points.
Doesn't really help, as we don't know the points to read the voltages from. I'm looking for points I can solder wire to so I can have a molex adapter on the card to read the voltage from.
http://xanderf.dyndns.org:8080/image...9800_front.jpg
http://xanderf.dyndns.org:8080/image...w9800_back.jpg
:stick:
dunno if people are still interseted in this but i've done the vgpu and vmem mods on a 9800 aiw, my card was originally a 9800se aiw but as far as i know the layout is exactly the same (my card is now essentially a 9800 aiw pro anyway cuz its hardmodded).
you can find all the information needed curtosy of ocfaq.com here
hmm im just now purchasing a used AIW 9800 Pro for my 2nd rig. is there any other articles or info about the vmods for this card?
