Well guys nventiv has released a new product :toast:
Here is the new nVENTIV Mach II ST available for customers all around the world.
With the evolvement of the new nVENTIV Mach II ST system, nVENTIV offers you extreme performance at a low cost. This new version of the Mach II has the same awesome cooling power as the original and approved Mach II but at a cheaper price. The product is avaiable in both the Enlight and Lian-Li design cases.
http://www.nventiv.com/log/SilverBlueSmall.jpg
Capable of removing 200W
Undisputed extreme performance
Condensation prevention
Lower noise operation
Improved start-up procedure
Mach II ST Chip-controller
Mach II compatible
New selectable housing system (aluminum)
"This chart indicates the performance of the Mach II ST model and the performance is similar to the original Mach II.
The purple line illustrates the evaporation temperature.
The blue line illustrates the CPU surface temperature.
This temperature is measured by the sensor which is placed just below the surface of the evaporator head pressing against the CPU. The sensor is mounted in the evaporator head by drilling a very small hole."
http://www.nventiv.com/log/STChart.jpg
