InWin DLITE
Introduction
InWin has launched of the DLITE, a new ATX chassis that borrows design cues from its existing Dubili line but aims for a more lightweight footprint. Available in Mocha Bronze and Lilac Silver colourways, the case features a distinctive wave-pattern front panel accented by a brushed aluminum strip.
https://i.postimg.cc/q7qDvkk7/1.jpg
This new offering targets builders seeking a balance of clean design, efficient cooling, and modern compatibility, all within a mid-tower form factor.
https://i.postimg.cc/dVHnXz80/2.png
Packaging & Contents
The primary front side of the packaging shows the InWin DLITE as a black line drawing. The chassis name is also present.
https://i.postimg.cc/DwMd51TW/1.png
At the back we find a blown up shot of the InWin DLITE.
https://i.postimg.cc/cC0Q6mQb/2.png
Rotating the package clockwise ninety degrees and we get a an inventory control sticker, likely from the factory, which makes the chassis. The InWin DLITE is available in two colors: Mocha Bronze and Lilac Silver. The one I received for unboxing was the brown version.
https://i.postimg.cc/htfVJh7r/3.png
The final spin of the package and we see the specification table for the chassis.
https://i.postimg.cc/N0XT4VDK/4.png
Foam spacers hold the chassis in place and protect if from damage during shipping, while a plastic bag has been put over the chassis to keep fingerprints and scratches away as it is put into its packaging at the factory.
https://i.postimg.cc/26FWpZPj/5.png
Parts include several disposable cable ties, copper standoffs to Phillips head sleeves, and mounting screws.
https://i.postimg.cc/h4smpVLr/6.png
The instruction manual requires scanning a QR code.
https://i.postimg.cc/WbfkPjfG/7.png
A Closer Look Outside
The chassis combines SPCC, tempered glass, aluminum, and ABS materials, featuring a corrugated mesh front panel and brushed aluminum accents. Its dimensions are 245mm (W) x 441mm (D) x 528mm (H), making it a substantial mid-tower. Its champagne gold mesh panel complements the brushed metal frame, while the dark main frame is paired with a transparent glass side panel. Resting on two imposing, stylish feet, it commands attention on any desk. It is paired with black glass side panels, giving it a very good texture. The tempered glass side panel showcases the entire configuration and the internal RGB lighting. It reminds me of those old speaker sets, giving it a high-quality retro feel. Its structure is simple and visually consistent. Out of the list we covered today, this one would perfectly fit in a living room, making it a prime candidate for those who play games on the couch.
https://i.postimg.cc/tRvTskt4/1.png
The four sides have columns. The columns on DLITE are decorative and integrated with the side panels.The DLITE model name is printed on the upper right side of the glass.
https://i.postimg.cc/vZfHSsRY/2.png
There are ventilation holes on the front of the right side panel, which support fans. These ventilation holes are finely meshed, so there is no corresponding filter inside.
https://i.postimg.cc/7L4PFWw8/3.png
The word DLITE is printed on the upper right side of the side panel.
https://i.postimg.cc/9M8WqX9s/4.png
The front panel features a large ventilation mesh.
https://i.postimg.cc/4yjsB8B8/5.png
It has a shape of small waves.
https://i.postimg.cc/52dfzRHd/6.png
The front I/O panel features a USB 3.2 Gen 2×2 Type-C port, two USB 3.2 Gen 1 ports, and HD audio.
https://i.postimg.cc/V66w1yhX/7.png
At the top, there is a 3 x 120mm or 2 x 140mm fan grille, compatible with 280mm or 360mm water cooling systems. The chassis features there an magnetic dust filter.
https://i.postimg.cc/3wrNyc6h/8.png
The rear side panels are both removable by pulling them out from the back and are secured with hand-turned screws, with a design to prevent them from falling off.
https://i.postimg.cc/26MSK85Q/9.png
It comes pre-installed with a 12cm XM120 ARGB fan at the rear. You'll find the eight expansion slots, each secured with screws. There's no 90° mounting system on this model. The power supply is mounted using a bracket.
https://i.postimg.cc/SQYsz8ZT/10.png
There is a large filter screen, which is magnetically attached and can be quickly removed for cleaning.
https://i.postimg.cc/GmdhNfbG/11.png
The lower foot pads are designed to extend from the column. It's made of plastic instead of metal, but the overall texture is consistent.
https://i.postimg.cc/fbbWW0t3/12.png
A Closer Look Inside
The internal structure uses most common architectures, with the power supply and hard drive bay located at the bottom. It supports ATX, Micro-ATX, and Mini-ITX motherboards, including BTF-compatible models from ASUS, GIGABYTE, and MSI, which simplifies cable management by relocating motherboard connectors to the rear. There is a fairly spacious area above the motherboard, and there are also cable routing holes. InWin provides three 120mm fan mounts for adding fans to the case. Note that water cooling is not supported in this location.
https://i.postimg.cc/VNSyH90T/1.png
The power supply shroud is well-ventilated and includes provisions for two 120mm fans, as well as a riser cable bracket.
https://i.postimg.cc/1XrbNJbn/2.jpg
Three 12cm fans can be installed on the right side of the motherboard. However, to the right of this grille, behind the front panel, we find three XM120 120mm ARGB fans from the brand.
https://i.postimg.cc/02ZLkXYR/3.png
A 360mm water cooling radiator can be installed on this grille, with a dedicated opening in the power supply shroud for this configuration. The front panel is detachable and secured with snap fasteners, pulled out from the side.
https://i.postimg.cc/26ptcsDN/4.png
The case's width (245mm) provides ample space for cable management, allowing users to easily organize power and data cables and prevent messy cables from affecting heat dissipation. There are also two cable routing holes in the rear panel. Of course, we also have a multitude of points for installing clamps. In terms of power supply compatibility, it supports "ATX standard power supplies with a maximum length of 200mm" and also features a removable mounting backplate, providing users with flexibility in choosing high-power power supplies. The power supply bay is equipped with wide foam strips.
https://i.postimg.cc/j2ckjCJd/5.png
The chassis also includes a 4-port ARGB/fan hub for streamlined control of lighting and fan speeds, with additional ports available for expansion. This device requires a SATA power connection.
https://i.postimg.cc/FsFBBb2K/6.png
At the bottom, we find the removable HDD cage and the power supply bay.The hard drive bracket needs to be removed before installation. It is secured by two screws at the bottom. The HDD cage can accommodate two HDDs or two SSDs.
https://i.postimg.cc/Dw8Y2vf3/7.png
Installation and Finished looks
Installing the motherboard is a breeze. Simply position the board and screw it in.
https://i.postimg.cc/qvyycSjz/1.png
For liquid cooling enthusiasts, there is room for a 360mm radiator at the front and another 360mm or 280mm radiator at the top.
https://i.postimg.cc/cJc32YqB/2.png
Installing the AIO liquid cooler is equally straightforward.
https://i.postimg.cc/PJ0vYQDB/3.png
Installing the graphics card is a simple process: unscrew the screws holding the brackets, slide the card in, and then screw them back in.
https://i.postimg.cc/W1Gqqr1Z/4.png
As for air cooling, there's space for a CPU tower up to 165mm tall.
https://i.postimg.cc/1tt8djcB/5.png
The PSU area is very big and easy to get installed. The specification allows for the installation of units up to 200 mm long, so even the largest structures can easily fit here.
https://i.postimg.cc/v84zgqwd/6.png
After removing the cover, the power supply can be inserted from the rear, but it could also be placed on the side. The included PSU bracket helps on that. Remember to get all PSU cables installed before mounting the power supply.
https://i.postimg.cc/4dqpQGkH/7.png
The removable HDD cage will be able to accommodate two HDDs or two SSDs. Adding drives is done with classic screws. Once filled, simply slide and clip it back into place.
https://i.postimg.cc/HkdX23RL/8.png
In terms of cable management, everything is designed to provide ample space for the cables we need. First, there's the large vertical opening, still as practical as ever, which makes it easy to route bulky cables like the 24-pin. Unfortunately, the case don't have rubber grommets.
https://i.postimg.cc/1XDV0NK5/9.png
Overall, the experience was satisfactory.
https://i.postimg.cc/fRzSXyS0/10.png
The lighting effects have 17 modes, which can be switched using the lighting effect button on the front panel.
https://i.postimg.cc/R0q3sYRm/11.png
https://i.postimg.cc/63v8wGgm/11-1.png
https://i.postimg.cc/vHM4FTz7/11-2.png
The front panel lighting effect is also visible, and it has a low-key feel through the mesh.
https://i.postimg.cc/0NLNtyjP/12.png
Test System
Hardware
Intel Core Ultra 7 265K processor
ASUS ROG MAXIMUS Z890 HERO motherboard
CORSAIR HX1500i power supply
NVIDIA RTX 5090 Founders graphics card
Samsung 970 Evo Plus 2TB SSD
RAM Kingston Fury Renegade DDR5-8400 CUDIMM 2 x 24 GB
InWin AR36 all-in-one water cooler
Performance
Here, we'll record the temperatures of several components in this InWin DLITE case. For this, we'll use our reference configuration. Regarding airflow, in the first scenario, the case comes stock with four XM120 120mm ARGB InWin fans. The three fans of our InWin AR36 AIO liquid cooler are exhausting at the top of the case. In the second scenario, we add two more XM120 120mm ARGB fans: two at the bottom. Let's start with the first configuration where our processor temperature peaked at 68°C with an average of 58°C. The motherboard's power delivery system reached a temperature of 47°C. As for the memory modules, one reached 41.2°C and the other 39.8°C. Our Samsung 970 EVO SSD reached a peak temperature of 60°C. Note that the motherboard's integrated heatsink is therefore cooled by the case's airflow. For the temperatures of our NVIDIA RTX 5090 Founders Edition graphics card, the results show a maximum temperature of 52.1 °C under load.
https://i.postimg.cc/tJbWM5JY/1.jpg
With the second configuration, and the two added fans, we gained 2°C on the average CPU temperature and 3°C on the maximum value. Overall, temperatures dropped by 2 to 3°C. Finally, we appreciate the presence of the four pre-installed fans. Temperatures are good, and the well-ventilated panels help a lot.
https://i.postimg.cc/02Qqwq2x/2.png
The last part of our measurements concerns noise. Here it does quite well.
Conclusion
This model embodies an ideal compromise between understated elegance, well-thought-out features, and meticulous finishing. A relevant option for those who want to combine style and practicality in their build. It's primarily in its thermal management that the DLITE reveals its ingenuity. It features a perforated metal mesh front panel that facilitates direct airflow, complemented by a side vent to the right of the motherboard for improved airflow. For ventilation, the case can accommodate up to 12 fans: three at the front, three at the top, two at the bottom one at the rear, and three on the right side. It ships with four pre-installed XM120 fans, a model currently exclusive to this chassis. The chassis features ventilation openings at the top and bottom, along with magnetic dust filters. Routine maintenance is hassle-free. The openings are optimized for fluid dynamics, creating a micro-circulation with the top intake and bottom exhaust, accelerating the removal of hot air. The dust filters prevent lint and dust accumulation, keeping the chassis clean and tidy at all times. Speaking of cooling, the recorded temperatures are good, so there's no need to worry on that front. For liquid cooling enthusiasts, there is room for a 360mm radiator at the front and another 360mm or 280mm radiator at the top. As for air cooling, there's space for a CPU tower up to 165mm tall. The chassis offers substantial clearance for high-end hardware, supporting graphics cards up to 380mm in length across its eight expansion slots. To assist with the build process, InWin has included a pre-installed fan hub capable of managing four sets of PWM and ARGB connections. The front panel also features a dedicated LED control button that cycles through 17 lighting presets. For storage, two 3.5″ and two 2.5″ bays are provided to accommodate hard drives or SSDs, depending on your needs. The front connectivity includes a USB 3.2 Gen 2×2 Type-C port, two classic USB 3.2 Gen 1 ports and an HD audio jack in CTIA format, compatible with headphones and a combined microphone. The number and specifications of the interfaces meet daily needs, and the addition of the Type-C interface improves expandability. Assembling the system in this case is relatively straightforward. There's ample space for neat cable routing. Just be sure to connect all the necessary cables to the top of the motherboard before installing the AIO cooler's radiator in the upper slot, as it will cover the connectors. While it's still possible to reach through the top to make connections, it's considerably less convenient. Similarly, once the two bottom fans are installed, the bottom row of connectors on the motherboard will be difficult to access. The back panel has ample space for cable management, and the functional areas are clearly divided. Multiple cable holes and cable ties make cable management easy and neat. The bottom compartment is spacious enough to accommodate various ATX power supplies. The lack of an anti-sagging graphics card bracket is a significant drawback. Users can only hope that the graphics card bracket included with the motherboard (an adjustable bracket with two locking holes on the lower right of the ATX motherboard, such as the ASRock SteelLegend series) will be sufficient.
https://i.postimg.cc/7LgvkHXq/1.jpg
To return to the question of price at 129€, it's worth noting that the case is not available in white or black, but in Mocha Bronze and Lilac Silver colour. The DLITE offers excellent value, especially considering the included fans and ARGB hub. The chassis is positioned as a strong contender for builders looking for a stylish, well-cooled, and feature-rich mid-tower case.
https://i.postimg.cc/8cnk6p2W/2.png
https://estore.in-win.com/products/dlite
