Vertical GPU Installation Mounting Bracket
A new video card is one of the biggest expenses you'll invest into your custom PC build. Why not show it off?
I want to inspire people to not be limited to traditional system layout. I've created a GPU mount that allows mounting your card over the 120mm fan hole or anywhere in your PC simple modifications. The Stage 2 version doesn't require cutting opening for monitor cable(s). It's made from .5" thick solid aluminum to support the weight of large non-reference coolers or water blocks.
https://www.youtube.com/watch?v=FBTq88-aUdI
