Originally posted by Micutzu20
Nevermind , i've discovered myself :toast:
DDTUNG told me where to get the data sheets for the IC's , i've downloaded them and done the vmods myself . Here's a brief description :
APW 7016 is the volt regulator for the GPU . You need to solder 2 resistors here :
- pin 1 is the overvolt protection pin , you need to put a 100 ohms resistor from here to ground ;
- pin 8 is the feedback pin of the error amplifier , put a 20k resistor from here to GND to get 1.75V instead of 1.5V .
APW 7036 is the dual volt regulator for the memory (it requires 3.3V and 2.5V) . Another 2 resistors on this one :
- pin 16 is the overvolt protection pin for the first voltage (2.5V) , soldering a 470 ohms resistor from here to GND gives you 2.85V instead of the 2.5V , because it also affects the feedback circuit (pin 15) ;
- pin 7 is the feedback pin of the error amplifier for the second voltage (3.3V) , you need to solder a 510 ohms resistor from here to GND to get 3.7V instead of 3.3V .
This is pretty much all , maybe it'll help you too , Ragnarok . For any other info PM me .
Do you have any photo of this v mod ?
