Kepler Boost Clock not working
Hi,
I got some gtx 670, which uses the 680 reference pcb (Zotac).
Software oc seems to work fine, so i went ahead to modify the vga bios, but the damn thing wont boost correctly.
Can anyone help me how this boost crap really works?
I set the base clock to 1006 Mhz, and put Boost and Boost Limit to 1202, yet it will only boost to 1054.
If it reaches 80 ? C it will go down one step to 1044 or sth. like that.
Power Targets have plenty of headroom (originally using 85 %, modded using 75 '% now und the testscenario as max used PT).
Below is a screenshot of KBTs settings ... why does this not Boost higher?
PT, seems not to be the reason, temp is not excellent, but it does not even jump higher as 1054 when the card is cold.
Thanks in advance :)
http://www9.picfront.org/picture/VRK...gk104_kbt1.jpg
http://www9.picfront.org/picture/qA8...gk104_kbt2.jpg
