Swiftech's New Products for 2014
In case you hadn't seen Swiftech announced a bunch of new stuff at CES. I was able to tour the suite and did a write up:
http://www.xtremerigs.net/2014/01/10...es-2014-suite/
Here's the TLDR:
- New H220 revamped now called the H220X, now comes with reservoir, and fittings are removable and G 1/4 based. Radiators are very space efficient and should be compatible with any fan mount and it comes with the new....
- Apogee XL
- New MCP50x pump that's more powerful than the MCP35x for less money and similar noise
- New Maelstrom V2 reservoir
- R9-290X Plexi Top Block
- Titan/780 Plexi Top Block (this was shown before CES though so not exactly news)
- All LEDs will move to RGB with a customizable controller at some point.
And some pics:
http://i.imgur.com/1nFp3qyl.png
http://i.imgur.com/GpFnEOkl.png
http://i.imgur.com/VbAf6T7l.png
http://i.imgur.com/ilpX08wl.png
http://i.imgur.com/WJusugSl.png
http://i.imgur.com/GFJy9dBl.png
http://i.imgur.com/3flG11Rl.png
http://i.imgur.com/ta03C7Sl.png
http://i.imgur.com/gs94dEil.png
http://i.imgur.com/pRLhBDOl.png
http://i.imgur.com/7AepEyQl.png
