AquaComputer MPS 400 Flow Sensor Review
The full detailed 5 page article can be found on my website. Here is a summary:
http://i.imgur.com/GHZKaIPh.jpg
The MPS 400 is the first flow rate sensor for water cooled PC's that uses a differential pressure sensor that has been integrated into a single silicon part. The advantage of such a design is that there are no moving parts that can break down and possibly stop the flow of coolant. It is also exceptionally small and can read an external temperature probe as well as having it's own internal temperature sensor and Alarm function.
Flow
The flow rate sensor should produce a temperature compensated voltage that is linearly proportional to differential pressure. This is converted by a DAC and communicated to the PC by a microcontroller via USB. The microcontroller also takes the "raw" DAC codes and plugs them into a calibration table which spits out a flow rate. Calibration tables are provided for 8 and 10mm tube, but not the common 7/16" and 1/2" ID tube (10mm and 3/8" tube are very close in size). You can even supply your own calibration table. The sensor is configured, measured and logged by AquaSuite, which is free and downloadable from AquaComputer's website. The sensor itself has high accuracy if enough averaging is used. Aquasuite however does not seem to average and instead has a secret sauce "filtering" algorithm which seems to just take the lowest value recently seen. By doing some manual averaging I compiled my own calibration and compared it to the default AquaSuite settings and 10mm calibration table:
http://i.imgur.com/d04HEst.png
By default AquaSuite rounds to the nearest 0.1GPM (although this can be changed in the settings) hence you can clearly see the steps that are due to that. However there is still a large source of error that is due to the calibration table matching poorly, and the error also falls off a cliff after 1.5GPM because the calibration table ends even though the DAC is still outputting useful data. If we plot the error of the two calibrations methods vs my +/-0.07GPM accurate King Rotameter:
http://i.imgur.com/STJfTtG.png
Then we can see that with "manual" averaging and a good calibration file then the MPS flow sensor is *very* accurate indeed up until it's *real* range ends at ~2.1GPM. However the supplied calibration file is not only a very poor match for this sensor but also ends unnecessarily soon.
Temps
The MPS 400 also includes an internal temperature sensor and an input for an external temperature sensor. The internal temperature sensor is not very close to the water and so is not only slow to react but has a large amount of error. To test the external temperature sensor I bought an AquaComputer in line temperature probe and I measured very similar results to my Dallas "one-wire" temperature probes:
http://i.imgur.com/RbP7VH1.png
This really shows just how bad the internal temperature sensor is. Again plotting the difference between the two sensors and my reference dallas probes shows that the external probe is very good:
http://i.imgur.com/vxLdTMs.png
Again most of the external error is due to poor calibration. I noticed a bump on both sensors at 30C and this turned out to be a rounding error in AquaSuite. AquaComputer are fixing this is in the next release of AquaSuite.
Alarm
The MPS 400 also has a configurable 3 pin "fan" header that can be connected to the motherboard or used to light or extinguish an external LED (not supplied). When connected to the motherboard and configured properly the sensor reads a fixed RPM. If connected to the CPU fan header then you will know quickly on boot if your flow is zero.
Summary
A very good flow rate sensor with a lot of potential let down by poor calibration. If you're willing to calibrate it yourself then it can be very accurate, if you're not then take the value with a grain of salt as it's main value will be measuring a relative change such as "has my loop become clogged because the reading has dropped by 1/2. Ignore the internal temperature sensor, it's too far away from your coolant to be of much use. However the external temperature sensor is a useful input to have. Similarly the alarm feature is a nice bonus too. The MPS400 is however pricey, currently retailing at $68 in the US this seems somewhat high given the poor accuracy and poor support for larger tubing sizes, if AquaComputer can fix these things then I'd say it's good value for money.
