Kenji's Murdermod V2 (with some murderbox parts)
I did a murdermod build a few years ago.. it was actually my first watercooling build. Learned a lot from it and decided this spring I would tear it down and do some spring cleaning. I'll be going from Standard ATX to Inverted which im pretty excited about. Ive already torn it down so I dont have any pics of that but ill post a status and start taking pictures from now on :)
Theme is Blue/Black with some red accents
Status : 30% complete
Hardware:
CPU - 980x -
GPU - GTX Titan
MOBO - EVGA E760
SSD - Samsung 940 Pro
PSU - Corsair HX 850 Sleeved
RAM- Corsair Dom Ram
Case - TJ07 Murdermod Style
Watercooling:
EK Supreme HF
Aquacomputer Aquaero 5 LT
Aquacomputer GTX Titan Nickel/Plexi Block with Backplate
mcp355 /w ek top
HW Labs GTX 480
San Ace Hr101 Fans
EK Motherboard block
LRT Advanced Tubing
iandh stealthres 250
To Do List:
Waiting for powder coater to finish with parts.
Need to get my side panel cut and a window put in.
Order replacement TIM and TIM pads to put blocks back on after cleaning them.
Drill holes in S-Light
Consider ordering replacement CPU Cooler
Plan out how to do a drain port in my loop.
Plan out loop order.
Buy rivets or replace rivets with screws during Case rebuild.
Paint CD ROM drive
Setup a tray system for my SSD
Setup a holder for my Aquaero 5 LT (will probably go in the cd tray bay)
Sleeve all Misc items (order some stuff from mdpc)
Test and resleeve all fans.
