Ok, ATI HCC GPU WUs are back. I tried to run 32 threads but my PC slowed to a slooooow crawl. Back to 16 threads and everything is good. Let's get this team back on top!
All Abooard..... The FAST Train!
I juat love the sound of crunching in the morning....:clap:
Starting a download of some now. Ohhhh yeahhhhhhh
Now where are the NV WUs? :shakes:
I have some. That rig is running straight, no app_info.
Maybe you need to Hit update and check settings Oj
running 16 wu and i have a full cache
Never mind, I have a few pages now :D I'll be off of GPUGrid after the current WU and back onto WCG 100% :up:
So did you all you guys running the appinfo files have to just remove them until this batch of GPU WUs came along?
I didn't. My PC was going to be off a lot this week anyway so I didn't bother with removing the file.
Once we were notified that GPU was pausing I changed my profile to accept all of the projects in the big app info on one machine then made a couple of threads available to cpu.....then once the rig had downloaded some cpu work I used the big app info.
The result was that once gpu work was done all cores continued doing cpu work on each of those projects until GPU work resumed then prioritised that again. I shall run a core in order to finish the cpu work and, once I figure the best way to limit the number of cpu work units held by this rig I think I may leave things as they are at the moment. The alternative is to stop cpu work in the profile and only re-instate it manually if there is another pause
