Originally Posted by
n00b 0f l337
Well. You do the evap all at once.
Drill the cap tube hole at an angle for your cap tube, make it go away from the spiral so the top layer gets flow. Then plant the 3/8" suction tube. Then put on the outside pipe.
Now braze it while pumping shielding gas through the capillary line. Keep the heat off the capillary (I have a jig and point the torch at the base of the evap until its red). I like to braze the bottom ring, then the top ring, then the suction tube, then the capillary line last. Try not to burn the cap tube.
