ASUS P8Z77 WS - ATX / Z77 Intel Core i7-3770K CM Stacker + 2nd WC Case
Time for upgrades. Using my existing build will change few components and rebuild a "new" PC based on the Z77 chipset.
The bases of this is whatever i have from my previous build.
Link-> 1)
and 2)
The watercooled extrenal case was rebuild as result of, a 2 year old at the time, "mild" affection, resulting into broken sides, front etc.
At the same time, need to keep it clear and able to modify some parts, gave birth to the idea of vertical rads, no front, no top, and simply a very simple design.
To the point.
The build will be based on the following items.
- Intel Core i7-3770K
- ASUS P8Z77 WS - ATX / Z77
- 16GB G.Skill DDR3 PC3-19200 2400MHz TridentX Series CL10 (10-12-12-31) Dual Channel kit
- Apogee HD (white)
- EK-Ekoolant CLEAR -1000 ml
- Laing DDC-1T-PLUS
- Laing DDC-18W
- Dual Reservoirs XSPC (dual pump)
- ThermoChill PA120.3 (i have both versions, the old and the newer, though is few year back) still working ok.
- Keeping my 2x HD4870x2. Still old but working, both are on water and so i dont see a point changing them now.
- Few SSD disks, 2T HDD etc.
- 2x 24" BenQ G2420HDB
I think a reasonable overclock is somewhere between 4.5 to 4.8 Ghz (i think)
Will be targeting for SDD+HDD caching
From what i read LucidLogix Virtu MVP with crossfire / multi monitor setup is no go. If you know something else, pls drop me a note.
Currently waiting for parts to arrive.!!
Will post pics as the project comes along.
Zotac GTX 680 + Watercool Heatkiller GPU-X3 GTX680 Hole
Received a very nice package from Watercool.
So lets start..
The task in hand is to a) remove the existing cooler from the Zotac GTX680 b) Installation of the GPU block, GPU-X3 GTX680 Hole c) test d) Overclock.
Removing the GPU cooler was not that difficult. Basically you remove all screws around the base, bottom and back side of the VGA card.
It looks like this after that.
http://img72.imageshack.us/img72/2034/img0493xy.jpg
By neo_rtr at 2012-07-05
Going over to the backplate. As I read from the instructions I am to prepare the screws and then the plastic nut.
http://img593.imageshack.us/img593/3462/img0494jd.jpg
Have to admit got a bit confused. Spend some time reading over and over. The reason is that are many more holes them screws in this arrangement. I mean holes on the PCVB of the VGA. The backplace + info page frm watercool explain the different of the the screws to be used. Fine with that.
I would have found it ever better, if they could provide some pictures to show how the arrangement should look like.
http://img585.imageshack.us/img585/5011/img0495e.jpg
http://img233.imageshack.us/img233/7691/img0496ju.jpg
http://img98.imageshack.us/img98/8163/img0498e.jpg
http://img856.imageshack.us/img856/4401/img0500wp.jpg
http://img59.imageshack.us/img59/3044/img0501mf.jpg
http://img526.imageshack.us/img526/4694/img0502pj.jpg
http://img689.imageshack.us/img689/4056/img0503gj.jpg
One thing that puzzled me was these two screws.
These do not fit the back place.
They are, from what I figured out, placed on the PCB, then attach the back place.
From the instructions, could not figure out if a) install the block on the VGA. Then use these two screws to hold it in place, (not secure it in place). Then attach the backplate.
The thermal pads, come pre-cut, and fix perfectly.
I noticed one side is a bit sticky. The other not.
Could not tell from the instructions which side to put facing the board.
I assume it does not matter. Better it does not matter as I used the sticky side facing the board.
http://img62.imageshack.us/img62/3940/img0509fv.jpg
http://img593.imageshack.us/img593/1858/img0510hf.jpg
Start looking better now..
http://img43.imageshack.us/img43/9082/img0513p.jpg
Also to note there is one more screw to put in order to hold the bracket.
http://img441.imageshack.us/img441/1628/img0514n.jpg
That is the small M3 one.
The GTX680 looks like this,
http://img580.imageshack.us/img580/1829/img0515xe.jpg
http://img213.imageshack.us/img213/1688/img0517wb.jpg
http://img833.imageshack.us/img833/1723/img0518gu.jpg
http://img4.imageshack.us/img4/9886/img0519ip.jpg
http://img411.imageshack.us/img411/3879/img0520mf.jpg
http://img690.imageshack.us/img690/9216/img0521g.jpg
http://img717.imageshack.us/img717/2349/img0528yy.jpg
http://img38.imageshack.us/img38/2714/img0529tw.jpg
I can only say that at start my GPU temp was 24C, Using MSI afterburner to test for temps 15min into full load was at top temp 38C. Ambient was around 24c i think.
