Opinions between these three familly type configuration
Hello,
It's been a while I haven't made a new pc. And it seems I'm getting old... :)
So I'd like your opinion on these three configurations I've prepared. The computer as you can see should be small, evolutive, quiet and cheap.
It will be used for basic use at home for wife and kids, but should be able to run a few non-demanding games right away, and bigger games later on through an upgrade.
Three sockets have been selected: AM3+, FM1, and 1155.
First config (1155):
Case:
Heden B1078CAL00 - 39,99 €
Case Fans:
Antec TriCool 92 - 6,90 €
Advance V-A120 - 4,90 €
Motherboard:
ASRock B75M - 69,95 €
Processor:
Intel Core i3-2100 (3.1 GHz) - 107,95 €
SSD Drive:
OCZ Agility 3 Series 60 Go - 74,95 €
RAM:
Crucial Ballistix Tactical 4 Go (2x 2 Go) DDR3 1866 MHz CL9 - 35,65 €
Wifi:
Netgear WNA1100 - 9,90 €
TOTAL: 350,19 €
Second config (am3+) (all the same except motherboard and processor):
Motherboard:
ASRock 880GMH/U3S3 - 76,95 €
Processor:
AMD FX 4100 (3.6 GHz) - 106,95 €
TOTAL: 356,19 €
Third config (FM1) (all the same except motherboard, processor and obviously an additional graphic card):
Motherboard:
ASRock A75M - 63,95 €
Processor:
AMD Athlon II X4 631 (2.6 GHz) - 74,75 €
Graphic card:
AMD Radeon HD 5450 512 MB - 26,95 €
TOTAL: 337,94 €
So as you can see the total prices are really close. That's one of the reason I find it hard to choose.
Also, this FM1 socket bothers me. It's more recent than an AM3+, but only supports up to 4 cores... That might be a problem for future upgrades.
AM3+ config looks good right now, but what about the future ?
Concerning the 1155, it doesn't seem worth the price considering the power it provides. The other two config provide more powerful processors. Also, the compatible motherboards in this "micro" size are generally much weaker in terms of connectors, RAM speed ...etc.
Now I only hope you guys don't tell me I did a terrible job and need to start all over ;D
Thanks a lot.
Alex.
ps: if you want me to get links for each components please let me know.
