Loop Maintenance Questions
Hi All,
a few months ago, i had built my first water cooled system and its working amazing. now as a few months have gone by, i want to make sure i can maintain it properly.
i have been using Feser One only as a liquid.
my goal is to find a way to clean the loop as much as possible without disassembling it, by finding a proper liquid composition and process to run through the loop so all the
bad stuff will be drained out.
i had read some ppl do it in the following manner :
1. drain coolant
2. mix 10% vinegar with 90% distilled water and fill the loop
3. run the loop for a few hours ( im gonna say ~3 just to put a number here
4. drain again
5. fill with distilled water and run for the same amount of hours as #3
6. drain again as much as possible ( will always have stuff remaining in the rads )
7. fill with coolant again
im looking for any experience and advisory here on whats the best way, whats the proper way, and if there are any potential problems
thanks all !
SECTORIX.
