Wireless N worth the upgrade for tablets?
I hope this is the right place to ask this...
I'm wondering if I would notice the upgrade from G to N for my Xoom and iPad 2.
I need more range on my WiFi at home. I want to be able to be out at the pool and use my tablets. I pulled my current router over to an open window seal yesterday, that ‘sorta’ worked, the single was still only about half-strength.
Would I be better off getting a stronger router (if so, how can you tell range?)
Or, should I pick up some amplifier?
This is the router I have now:
Linksys WRT54GL
http://www.newegg.com/Product/Produc...82E16833124190
