Cosmos II Watercooling 2012
So after mulling over my water cooling choices I have settled on a internal build with my thinner Koolance Radiators. This is a recycle build with a majority of my parts were taken from my last water cooling rig, may you rot in hell GTX 295 failures :|. Anywho check the list of parts.
Case: Cosmos II (should have got the NZXT Switch 810, but meh)
Motherboard: Asus Crosshair V Formula
Memory: 16GB (4GBx4sticks) 1600 DDR3 Corsair Dominator
CPU: AMD Phenom II X4 965 Quad Core (may look at 8core in the future, but for now the Quad works just fine)
Hard Drive 1: Corsair P128 SSD
Hard Drive 2: Western Digital 300GB Velociraptor
Hard Drive 3: Western Digital 300GB Velociraptor
Hard Drive 4: Samsung 500GB HDD
Hard Drive 5: Western Digital 1.5TB Cavalier Green
Video Card: Sapphire AMD HD 7970 (reference board)
Optical: Random SATA DVD Burner
Power Supply: Enermax 1050Watt
Water Cooling Parts:
CPU Waterblock: Koolance CPU-360 (lets hope it passes its leak check when I go buy some distilled water from the store this week, I just reassembled after a long cleaning)
GPU Waterblock: Koolance VID-AR797 (will order Thursday)
Radiator 1: Koolance 360 Copper 30FPI Radiator (needs to be cleaned, painted, and leak tested)
Radiator 2: Koolance 240 Copper 30FPI Radiator (needs to be cleaned, painted, and leak tested)
Pump: Koolance 450 w/ pump top
Reservoir: EK 140 Multi
Fans: Varied
Fittings: 13mm compressions, varied
Fluid: Clear Koolance Fluid (will order Thursday)
Tubing: 13mm blue Koolance tubing (will order Thursday)
CPU>drain vent>Reservoir>240 rad>pump>GPU>360>CPU
Well you have seen the parts so here are some pictures of the set up and the parts I have atm.
http://img.photobucket.com/albums/v4...ing2012002.jpg
Other fans are not pictured XD
http://img.photobucket.com/albums/v4...ing2012003.jpg
Salamander Company Champion request the radiator be clensed of taint
http://img.photobucket.com/albums/v4...ing2012006.jpg
Clean wiring :D
http://img.photobucket.com/albums/v4...ing2012007.jpg
Mmmm clean wiring
http://img.photobucket.com/albums/v4...ing2012008.jpg
360 will go right here *points*
http://img.photobucket.com/albums/v4...ing2012009.jpg
one of the delta fans might go here at the exhaust
http://img.photobucket.com/albums/v4...ing2012010.jpg
240 radiator with two delta fans will hang out in the basement, along with the pump.
No cutting or hacking or modding is planned.
