URGENT HELP NEEDED: PC will not boot!
Ok fellas, here is the scoop. A month ago or so i pulled the trigger on that new SB Z68 machine i was talking about in my other thread, some of you may remember. Well, now the damn thing is experiencing some very BIG issues. It started soon after i built it. First it did not want to power on once every so often. It would attempt to stat powering on, then fail, power off, then attempt to power on all by itself. It would do that for a while, maybe 3 cycles, then either boot up and post just fine then load into windows, or fail completely. At which point i would power it on again and it would usually boot up just fine.
Now the problem happens almost every single time.
To make matters worse, the machine sometimes doesn't want to power on at all, but gets caught in an infinite power on for a second then power off, then back on....will do that until i pull the plug and kill it. Sometimes i have to fiddle with it for 30 minutes until magically and for no apparent reson it starts working.
Then last night happened. Twice while i was modeling and rendering the machine just shut itself off. Upon reboot it posted fine, but the mobo displayed a message telling me that it had shut itself off to protect itself from power surges it detected from the power supply. I had one option to go into bios, at which point i did, then save and exit the bios and it worked fine.
One other thing to note, ive watched the power on lights on the mobo to see where it hangs, and ive noticed it always fails while powering on the cpu. That power light comes on, stays on, then the machine shuts itself off again and restarts the cycle. Always on the cpu. It never gets to the ram or the video card. A bad cpu? A bad cpu socked? But the thing that bugs me is that the machine works fine one its powered up. No warning lights on the mobo, and no other issues at all! If it were an issue with the cpu or the mobo, i think i would have other problems besides boot issues.
Ok, thats the rundown of the issues im having. Now here are the system specs:
2600K
ASUS P8Z68-V PRO
EVGA 580GTX 3GB
Corsair 850TX PSU
Corsair H100 CPU Cooler
Corsair Special Edition White Graphite Series 600T
G.Skill Ripjaw X Model F3-12800CL7D-8GBXH
Crucial M4 64GB
Western Digital Caviar Black 1TB
I am not running any sort of OC, mainly because i havent been able to reliably get the damn thing to boot without having problems. Ive checked all the power connections and components, short of reseating the CPU ive done everything i can think of. If it is the power supply, what gives? All the components i used are brand new, and once it is running it has passed ALL the torture/stress/stability tests i have thrown at it with flying colors. Simiply, it runs like a champ.
But i keep coming back to three potential problems:
Bad PSU
Bad CPU/Socket
Bad ATX switch on the case
Any ideas?
