LSI 9240-8i + ASRock Z68 Extreme4 Gen3 boot error and JBOD
Hello forum members. ;)
I got problem with my LSI 9240-8i card, it's branded as Fujitsu Siemens but basicaly it's LSI 9240-8i without Raid5 just like IBM M1015.
http://img854.imageshack.us/img854/2...i92408i.th.jpg
Some specs http://allegro.pl/lsi-megaraid-0-1-s...978142645.html
I bought it few months ago, it won't work with my GA-MA790FXT-UD5P so after changing my rig to ASRock Z68 Extreme4 Gen3 i'm almost finished, but few problems appeared, normal version (without gen3 plx chip which could be a problem here) of this board was tested with LSI cards so I choose to buy a newer model.
Marvell rom boot option is disabled, but LSI makes win7 is booting very slowly and then after few seconds I got this massage "Controller encountered a fatal error and was reset" [IMG]http://img27.imageshack.us/img27/9962/msmerror.th.jpg[/IMG]
I could live with it as long as MegaRAID Storage Manager works ok, I can't open webios probably because I'm using Intel Raid - 4x500GB HDD (in future with some SSD SRT) on this board.
I don't have any free sata ports on intel/marvell controllers so I want to use LSI to connect a few HDDs with data on it. My main problem is that I don't know how to use jbod function. When I connect some disks to LSI, then I can make it to assign as a "Hot Spare Disks" which if I understand correctly are backup drives for a raid configuration, or I can make a single drive to be a member of virtual drive. Last option give me only Raid0 choice, kind of misleading but it's single drive in raid0 configuration. All would be ok with that, but making a such virtual drive destroys all data after initialisation process, what I try to avoid.
LSI card flashed with latest firmware from LSI site, newest drivers and MSM, tested with latest asrock bios
I would be very thankful for any help
