Best dual top (serial) for Liang ddc
Hi guys !
I got the problem of selecting a double top (serial) for pumps swiftech 350. Is present in the market quite a few options, but none of the normal testing.
The only test that I found shows only the flow rate but not the pressure in the circuit.
http://www.xpert-oc-team.de/forum/vb...rwk_ld_vs_2l15
My choice is tops among the following:
Aquacomputer aquacover dual DDC, top for Laing- and Swiftech pumps, G1/4
Watercool Dual DDC-Case LT Acryl
EK Water Blocks EK-DDC Dual TOP V.2 G1/4 - Black Acetal
XSPC Laing Dual DDC Acryl top
My main priority is performance, and noise level (and vibration).
Most of all I like aquacomputer for connection variability in the contour. But based on the existing test, it is the weakest performance (a test in German, about the noise I can not say anything:))
Top EK is the most expensive, but there is no test data and its performance can only guess. A big plus Ek top decoupling kit.
In general I am confused what to choose.
I would appreciate any help in this matter.
p.s. And more interested in how you can reduce the noise level of the two pumps, is there a ready solution.
