Motherboard Tray - searching for dimensions, please help!
Hi ppl! :)
As the title implies, I'm currently preparing for making my own case, scratch build, and need a hand with MB tray. Want to make a MB tray that is compatible with HPTX/XL-ATX/E-ATX/ATX (mATX - as they use same holes). If possible with PCI slot's back panel too, if not I will buy some (PPCS sells DD ones e.g.) or use one from other case. So, my main trouble is hole spacing on MB tray for these standards, to check do they share some of them? Any chance to get some diagram for this with dimensions of hole spacing?
I've searched the net, but no luck. Also would be very expensive for me to buy one from MM or any other vendor (even PPCS from where the group of us makes group order from time to time so we save on shipping) cause of shipping and the overall price. For that amount I can get all the mats ( alu sheets, rails, plexiglass etc.) I will be needing for my future project.
There has to be some data on this, someone was in my situation for sure. Please help, any info is appreciated. Thank you all. :)
Sorry, for posting this here, was a dilemma where to post it. Here or in the mods section, but think it will be well here as most of scratch builds and case mods are done for WC purposes.
