Smallest case possible for two 240mm rads inside.
The config, size-wise:
P8P67M-PRO
GTX560ti ( x2)
Corsair HX650
Xfi Titanium
1 SSD
This is the loop:
1 rad is "thick" 45mm
the other is "thin" 30mm
http://img508.imageshack.us/img508/7532/sdc16063.jpg
I'm taking a look ath the lili PC-05NB, rads top and bottom would do. But $ is getting too much high for people from overseas, so I'll take my shot in other options first, if possible.
In Win Dragon Slayer could fit top and front, since the video cards are kinda short.
I'll take any suggestions in consideration. Any brand, but no HARD mod on the case, like those OEM :banana::banana::banana::banana: that you need to remake it all.... something with appealto the job , ar at least less mod intensive...
tanx
