the easiest, obviously a sharpie. ^_^ lol
but for the best in looks, the typical way is to paint it. you can get 'plastic' spray paint pretty cheaply at hardware stores and can give a very nice look.
i'm going to point out something new that i've ran across recently. over on
overclock.net i read that thread. they go through steps on how to use rit dye to dye keyboards & the keys. in that thread there are a few who mention that they've dyed rom drive covers. it can be a bit trickier than keys due to them being so much thinner. but it is doable.
the way they do it is take the dye to a boiling point and soak the parts in the dye. powder or liquid version, both work.
clean the parts to be dyed very well. make sure there's nothing on the parts that could cause the dye to make contact poorly in some areas over others.
boil the dye, remove from the heat and let cool just a little bit. place the plastic parts into the dye. keep the liquid over the whole part. let it sit in the dye for a few minutes. with keys they say 5 minutes (roughly) then pull it out and rinse it off, letting it cool.
repeat several times, many times if need be.
it's better to submerge the parts 5 to 10 times in short durations than submerge once or twice for a longer duration.
the shorter duration helps prevent possible warping of the plastic and gets the dye into the plastic better.
just do that repeatedly until it's reached the coloring you're wanting.
some of the pics of this done to keyboards look really slick imho. i've actually been planning on doing this at some time in the near future.
if my post here doesn't make sense just read the thread some. they explain it pretty thoroughly there on how to go about it and get it done well.
