Water pump pressure drop help OR when should the water loop be closed.
When I turn on my Swiftech MCP35x water pump with it open to the atmosphere I notice the water level in the reservoir above it drops. When the pump is turned off the water level in the reservoir rises. I do understand water block will increase the resistance to flow of the water based on their specific design and the water flow rate.
Should I fill the reservoir with the pump on and then seal it or fill the reservoir with the pump off and then seal it.
Is it advisable to leave the system open to the atmosphere so it will normalize pressure in both situations?
Which pressure level is the recommended one?
Here is my setup. The water goes from the reservoir to pump to radiator to chipset to cpu to gpu and then back to the reservoir.
https://lh4.googleusercontent.com/-t...0/DSC_0487.JPG
Heres a short video example of what I'm talking about. The clear tube is open to the atmosphere.
The MCP35x starts at a low flow rate, it increases to max flow rate, and then returns to a low flow rate. In the middle of the video you will see the water in the tube drop and towards the end it will rise back up.
http://www.youtube.com/watch?v=tm-4kJFSNWo
Any advice would be helpful.
Cheers
