GUIminer
I just downloaded the updated GUIminer for this month and noticed a very nice speed increase. My 5850 went from 300-304Mhash to 320Mhash using -v -w128 -f0 and my 6950 went from 358-360Mhash to 372Mhash using the same flags on both cards and versions. I was using last month version.
https://github.com/downloads/Kiv/poc...r-20110701.exe
changes fps if you are not using the computer you can get a speed increase that way also. I think I read that defualt is 30. The lower the number the slower web pages move and windows move.
hmm, this latest version cause a drop in Mhash/s for my 580s, but I'll try it on my ATI rig and see if it can improve any.
Im kinda giving this a try with my 480 .... getting a ati card or 2 soon. So after I got over he initial issues with bitcoin app not getting enough connections (port forwarding issue) I tried setting it up on a pool and then I was stuck coz I hadnt setup a worker in the pool. So when I got that done it worked on slush's pool for a bit but since then the last 2 days ive been on and off solo mining but havent been able to connect to slush and btc guild via guiminer. I have registered worker and everything it just keeps saying connecting but never connects. Solo mining works with no issues at all.
