2 questions occured - tubing and fan related
Hi all!
I'm getting ready to make my case this summer and was just about to order some stuff from PPCS so 2 small dilemmas occured since I'm trying to save some cash...
Should I take Tygon R3400 or PrimoChill PrimoFlex Pro LRT tubing, will be taking 1/2 ID, 3/4 OD?
Pros and cons please from those that used this stuff. How long they last? How flexible they are etc.
Second one, well I need 2 140 mm fans for ventilating the future case, so which one would you recommend for those purposes?
Also concered about their longevity, noise and airflow etc. They will be placed as intake fans cooling the HDD and pump that will be behind them and getting some fresh air for the radiator which will be closed inside the first floor of the case...
Thanks in advance for your thougths.
Cheers! :)
Ed.
Oh yeah! Forgot to tell you that I'm looking at some Xigmatek fans atm and some Yate's. Really interested in those two fan groups. So would like to hear someone that used those ofc.
