Project [Mac G5]:Dipp | Problems need help | 28 june | 27 june
http://img853.imageshack.us/img853/290/namnlsqu.png
Hello!
I have been sitting on this side for nearly 2 years, and been regristrerad in four months and now i feel that i have to start the project :hip:
It is the first time I write a project log and my first time making a real attempt to modify a case and start writing in English on the Internet.
(My English is so bad that I use Google translate to spell and form mud me as right as possible)
But you and some other sites have compelled that I must try when there are so very many beautiful and wonderful buildings.
The construction that has made that I've chosen to make my project and made my goals are:
http://www.bit-tech.net/modding/2008...uo-by-cyprio/1
So now I take the collar and presents my building:
The name came to me from what I felt I want to achieve with my project, and it was these words:
Design
Innovative
Staff
Passion
and now to the case and my ideas.
The case, which I will modify a Powermacs that I got hold of 4 months ago, but the project has been the plan led to almost a year.
What I had in mind and make the chassis was to change it so that I can get a water cooling system for an ATX system.
It can be seen on skis further down that I want to fit a 2x120 and 3x120 radiator, then I would also be able to press two 80mm fans in the rear of the chassis.
I have come quite so long in my head how I should have most of it and how it should look like, but I still have an incredible number of ideas that are smoldering and that I would like to test.
My skises:
http://img860.imageshack.us/img860/1513/unledhxj.png
http://img146.imageshack.us/img146/7936/lolarna.png
And my first try to rendering it:
http://img864.imageshack.us/img864/8...2011061719.png
So here I have now presented the building and this is what I have so far managed to today:
http://img691.imageshack.us/img691/8826/img0231pnz.jpg
http://img35.imageshack.us/img35/8162/img0258oy.jpg
http://img268.imageshack.us/img268/8528/img0256uy.jpg
http://img40.imageshack.us/img40/4483/dsc0308kn.jpg
http://img823.imageshack.us/img823/6448/dsc0303g.jpg
http://img717.imageshack.us/img717/5186/dsc0310lz.jpg
http://img228.imageshack.us/img228/2392/dsc0314g.jpg
http://img683.imageshack.us/img683/6449/dsc0316y.jpg
And right befor i did leave the case i did dismount it:
http://img685.imageshack.us/img685/9340/dsc0319kq.jpg
This is all from me right now but will come more later,
//Stark.JR
The back is put together | 27 june
Hey all :P
Today I had a little time after work so I have started epoxy glue the back cover.
It was not quite as easy as I had thought it would be but time, some of it was good or not, the fact it takes 12 hours for the glue to dry.
This is the glue I use and it must be sick so strong hope that and the screws are able to keep everything together.
http://img98.imageshack.us/img98/1843/dsc0311t.jpg
Also received a small boost of the good weather that I would shoot out, so took my stuff that I had sanded down and went out in the sun and began to shoot:
http://img26.imageshack.us/img26/8203/dsc0310sq.jpg
http://img851.imageshack.us/img851/8306/dsc0308n.jpg
http://img685.imageshack.us/img685/8445/dsc0304dv.jpg
http://img860.imageshack.us/img860/9273/dsc0306h.jpg
Unfortunately, I do not really photographer I thought I was :( :oops: but you can see what it is anyway haha
Here are pictures of the glue before mixing:
[IMG] http://img339.imageshack.us/img339/9962/dsc0313b.jpg [/IMG]
Here are some pictures of when I put on the adhesive and the heated 200 degrees when it gets particularly strong when:
http://img221.imageshack.us/img221/492/dsc0315x.jpg
http://img233.imageshack.us/img233/7040/dsc0318o.jpg
And last but not least, I have just found out where my hard drives to be, and I will just run the 2.5 drives (SSD) in this project when I have such a small place and has begun planning for a computer that will become the server:)
http://img829.imageshack.us/img829/4531/dsc0321p.jpg
This was all from me right now but maybe one more update this week will see how much it is at work :lol:
/ / Stark.Jr
Getting into problems, asking for help :) | 28 june
hello all again today :)
Here's a quick little update on how things have gone for me with epoxy glue and sanding.
How did it look like now after it had stood for 24 hours of drying time:
http://img84.imageshack.us/img84/853/img1068gx.jpg
I can say that this epoxy glue is so sick tight that there is :D, because I tried which is to share it when I realized that I had failed to put your stuff that holds the video cards, sound cards and the like :wallbash: . But it did not really get away I tried with that which existed even with chemicals, but it did not come off so I had to drill more holes in the chassis and replacing the graphics card holder.
How it looked after I got your graphics card slot and avoid of any excess glue that was left:
http://img534.imageshack.us/img534/7775/dsc0312is.jpg
On this picture you can see even my little problem I have but do it later.
I can also say that I am incredibly pleased with myself how awesome I have managed to fit into coherent with each other, the thought that the little extra Bitten I sawed out and put in would be completely skewed to those sides who is already in line with the chassis :dremel: :lol:
http://img832.imageshack.us/img832/8595/dsc0313t.jpg
Here you can see even better how coherent fits in line with each other:
http://img51.imageshack.us/img51/2200/dsc0306dd.jpg
And now for my major, or perhaps a small problem I have:
http://img853.imageshack.us/img853/5525/dsc0317l.jpg
One sees it not so well but the problem is that I have sanded a little too much on the edge so you can see my graphics card holder and what I wonder is what putty is to be used anyway?
Is there anyone knowledgeable in this area that could explain why I should use such a filler?
In the end I really can think of to keep there and would sit down would be fiber filler, but I can type anything so I ask you for help :)
/ / Stark.JR
