I am trying to start up some GPU's and I keep getting the same error on 4 different rigs? How do I fix this?
Click the button for "no new tasks" and then hit the "update."
If that works, once you allow new tasks it should continue to work. :up:
The other suggestion I found is to restart the client. :shrug:
Detached from project...no go
DL new drivers...no go
WCG runs no issues...All preferences are correct
What's going on???
this is weird for sure- did you post over at GPUGRID forum?
Nothing of value back from the forum????
From a few searches it looks like a communication / network problem. That explains why it is more than one machine. If all machines are able to ping a internet host then I would reboot and try the update again.
Hmmm...The PC's are at work. WCG no problem, F@H no problem, GPUGRID...BIG PROBLEM....Does anyone know the IP Addy of the GPUGRID server? Is it using Port 1080? anything else?
I recommended the reboot to clear out any DNS cache or network "dust bunnies".
Non-authoritative answer:
Address: 62.149.128.151
Address: 62.149.128.154
Address: 62.149.128.157
Address: 62.149.128.160
Address: 62.149.128.163
Address: 62.149.128.166
update uses 193.146.190.61 src port 80 dest 57285
