Originally Posted by
NaeKuh
shall i tell you my story version?
or you want a direct version to this answer?
Story version:
i'll have to search it.. but its a good story! :rofl:
Direct Version:
Conditions... what water your using... also, how much light is in the system present.
If you have Cold Cathods, or a lot of led's, and im talking.. like u can have a full on rave led party inside your case, then you will need both.
anti microbes solutions will degrade over time, or deposit on your tubing.. or even possibly diffuse out of solution in concentration over time.
Time being several months... up to 1 year.
If your starting with distilled, and your lighting is to a minimum... like your basic mother board leds + a couple others... Then you wont need anything but silver.
Distilled is naturally aggressive, and will start leeching silver + copper ions immediately.
If your tubing gets direct sunlight, then you are straight up fubared... nothing will save you from that.
Not unless u do a 3/4 glycol mix.
