Project Gemini Rebuild (SR-2)
So, like many of my builds this one has a history :)
It has been a AMD XP1800, E6300, Q6600 B3, then a Q6600 G0 @3.4Ghz then lastly an i7 920 D0 @ 4.0Ghz
Cooling wise its been on air, H20-I20, H50, and then Custom water.
It was the first rig I ever watercooled, and doubles up as my VMWare server, running 3 hosts.
It also is a 24/7 Folding@home machine :o and at some state (probably at the E6300 stage) got named Gemini
Lets concentrate on the most recent spec, then go onto the build spec and progress from there :)
Pre-Upgrade spec:
Cpu: i7 920 @ 4.2Ghz
Mobo: Asus P6T X58
Ram: OCZ 13333 DDR3 Low Voltage 12GB (6x2GB)
Case: Lian-Li A16B
CPU Block: XSPC V3
Pump: EK 4.0
Rad: XSPC RS240
Res: EK Multires
Tubing/fittings: 8-10mm white tubing on compression fittings.
Threw the build together from spares (bought the pump) after an unsuccesful build with the H50 (too hot) and this is how it looked.
http://i232.photobucket.com/albums/e...3082010196.jpg
Sitting at around 70°C and pushing somewhere around 33K PPD on a bigadv 24/7 it was stable as a rock. :D
But I had a plan, I wanted to reduce the number of GPU's I was running yet not lose any output and save some money on the electric bills.
And then the hardware was released that would make Gemini live to its name....
The EVGA Classified SR-2 (Super Record 2)
http://i232.photobucket.com/albums/e...55-A1_MD_1.jpg
With dual 1366 sockets for Xeon CPU's and Overclockable to boot the spec sheet read like a hardware nuts wet dream. ;)
Code:
Part Number 270-WS-W555-A1
CPU Support Intel Socket 1366 (Xeon 5600/5500)
Chipset Intel 5520
Memory Support Dual or Triple Channel DDR3
SLI Support 2-way, 3-way, 4-way
SATA Header 8
SATA Type 2x600MB/sec / 6x300MB/sec
USB Ports 2x3.0 / 10x2.0
PCIE Slot 7 x PCIe x16/8
Integrated LAN 2 x 10/100/1000
It would be mine.. oh yes! :p
