4 Deployment using software distribution system (Scenario #1)
The instructions below provide details on how to prepare World Community Grid’s BOINC client so that it can be
deployed silently from the command line. After performing these modifications, the command line will install the
client and automatically attach to World Community Grid using the specified member.
4.1 Determine Installer Properties
The installer requires some information during initial execution to install quietly on a system. These three are
critical for mass deployments:
1. PROJINIT_AUTH: Obtain the weak account key for the member name that you want the computers to
register under by visiting
https://secure.worldcommunitygrid.or...ewMyProfile.do. (You will find it
near the bottom of the page next to the text that says ‘weak account key’.) This setting is required.
2. ENABLESCREENSAVER: Default is 1 which sets the operating system to use the World Community Grid
screen saver. If you wish to not set the screen saver, then include ENABLESCREENSAVER=0 in the
commandline.
3. ENABLEPROTECTEDAPPLICATIONEXECUTION2: Default is 0. This is used to set application
sandboxing for improved security. It also sets whether or not to run as a service. If you want to enable
protected execution and run as a service, then include
ENABLEPROTECTEDAPPLICATIONEXECUTION2=1 on the command line.
For more advanced options please visit
http://boinc.berkeley.edu/wiki/Creat...ler_properties or contact
support@worldcommunitygrid.org .
4.2 Execute the installer
Now that all the options have been determined, the following command can be used to install the World Community
Grid BOINC client:
wcg_boinc_6.10.58_windows_intelx86.exe /S /v"/qn PROJINIT_AUTH=weakaccountkey
ENABLEPROTECTEDAPPLICATIONEXECUTION2=1"
As part of the installation, the computer will be rebooted. If you need to disable this, you can run the following
command. Please note that the computer MUST be restarted, before the software can start running.
wcg_boinc_6.10.58_windows_intelx86.exe /S /v"/norestart /qn PROJINIT_AUTH=weakaccountkey
Please note that there are several installation types and additional installation options available for World
Community Grid’s BOINC client. Please view this page to see them:
http://boinc.berkeley.edu/wiki/Creat...tom_installers or contact
If using any of these other options, please test them to make sure that they work correctly.
The BOINC client will not start automatically after running this command. It will start after reboot.
