Skyhawk Aluminum case $19 + $9.95 shipping
$19 at dealsonic. Was searching for a fortron 530watt PS and i came across it. I added the fortron PS to this case for $68 and shipping stayed the same. You cant even buy too many steel cases for this price. The front is aluminum too, no plastic like most other aluminum cases.
http://www.dealsonic.com/4692.html?A...268435&SID=998
I've used this case before, it is thin aluminum, It does have a Duct system to vent CPU heat out the back. Costs $4 extra if you want it. Paid like $35 for the case before.
They have other nice cases, So if you looking for a good supply at the same time, this might be for you if you look around @ other cases they have.
My linkie for a thread i started on the fortron 530
http://www.xtremesystems.org/forums/...threadid=26280
Dealsonic has killer reseller ratings. 9.62 out of 250 ratings
http://www.resellerratings.com/seller2792.html
I hit them a lot for Lite on drives, Usually 52x is around $40 and 16x DVD is $32
Been using the lit on combo 16x dvd, 48x CDRW combo drive they have for $51 also
Check their prices on external USB2 and firewire enclosures, they are always the cheapest Just ordered a Lite-on 8x DVD burner and an enclosure. $139 for the DVD burner.
