[Best Bang for the Bucks]GIGABYTE P67A-UD3R + Intel Core i7-2600K - 5GHz++ inside
After testing GIGABYTE flagship P67 chipset based motherboard here, this time i'm testing the entry level model, GA-P67A-UD3R.
http://www.gigabyte.com/fileupload/p.../3650/3627.jpg
Main features from P67A-UD3R are :
- 8 Phase Analog PWM with driver MOSFET
- 4 DIMMs DDR3 up to 32 GB
- 2* PCI-E slot x16 (x16, x4) only support CrossfireX mode
- 2* SATA 6Gb/s + 4 SATA 3Gb/s supporting RAID 0,1,5,10
- 4* USB 3.0 + 14* USB 2.0
- 8 channel HD Audio and 1* GbE LAN
Testing Platform
Processor Intel Core i7-2600K Retail L041B204
Motherboard GIGABYTE GA-P67A-UD3R F7A and F7B BIOS
Galaxy GeForce GTX 470 1280 MB
Memory GSkill F3-17600CL7D-4GBPIS running @ DDR3-2133
Kingston SSD Now! V Series 64 GB
PSU Antec TPQ 1200W
Noctua NH-D14 + 2x Fan 3000 rpm
Windows 7 Ultimate 64 Bit
Something i must explain before you guys see all the screenshot, CPU-Z can't detect the actual vcore properly (i'm using CPU-Z 1.56.2 and 1.56.1), the only way to see actual vcore is measure directly using DMM or using Easy Tune6.
You can see the screenshot below, notice that i set LLC = ENABLE.
Vcore idle = 1.512
http://produk.myclub.co.id/wp-conten...ch_52_idle.JPG
Vcore full load = 1.488
http://produk.myclub.co.id/wp-conten...nch_52_run.jpg
OK, let's see how it will perform in air cooling overclocking
5.0 GHz Result
http://produk.myclub.co.id/wp-conten..._5ghz_2133.JPG
5.2 GHz Result
http://produk.myclub.co.id/wp-conten..._52_finish.JPG
http://produk.myclub.co.id/wp-conten...pi_52_2133.JPG
http://produk.myclub.co.id/wp-conten...st_52_2133.JPG
http://produk.myclub.co.id/wp-conten...ge_52_2133.JPG
http://produk.myclub.co.id/wp-conten...me_52_2133.JPG
5.3 GHz Result
http://produk.myclub.co.id/wp-conten...ch_53_2133.JPG
http://produk.myclub.co.id/wp-conten...pi_53_2133.JPG
http://produk.myclub.co.id/wp-conten...st_53_2133.JPG
http://produk.myclub.co.id/wp-conten...ge_53_2133.JPG
http://produk.myclub.co.id/wp-conten...me_53_2133.JPG
5.4 GHz Result
http://produk.myclub.co.id/wp-conten.../3d05_5400.JPG
http://produk.myclub.co.id/wp-conten...pi32m_5400.JPG
http://produk.myclub.co.id/wp-conten..._5400_2133.JPG
http://produk.myclub.co.id/wp-conten...prime32_54.JPG
5.5 GHz Result
http://produk.myclub.co.id/wp-conten...3dm05_5500.JPG
http://produk.myclub.co.id/wp-conten...pi1m_5500a.JPG
http://produk.myclub.co.id/wp-conten...pi32m_5500.JPG
http://produk.myclub.co.id/wp-conten...fast_5500a.JPG
Validation 5.5 GHz : http://valid.canardpc.com/show_oc.php?id=1604822
http://img140.imageshack.us/img140/6299/valid55.jpg
My conclusion using this P67A-UD3R
- Performing well in OC with cheaper price compare to UD7 and UD4
- Vdroop quite big, hopefully it can be fixed soon
- Easy to run DDR-2133 with high CPU clock
- BIOS corrupted issue using F7A BIOS when OC, has been fixed by F7B BIOS.
- No pin burn or broken after pushing the CPU to the limit :p
