GPU doesn't boot when using displayport
Hello all,
I've been troubleshooting a problem on my pc since Tuesday. When I shutdown the pc the 2 digit lcd display on my motherboard lights up with the error 8.8. And when I turn the pc back on my 6950 fan spins at 100% and I get no display output. However the pc boots fine and I can use it through rdp. The error code displays regardless of power to the pc, I.e. it shows whether the power is connected to the psu or not.
Through troubleshooting the problem I've identified that disconnecting the displayport cable or unplugging the power from the monitor instantly turns off the error and the pc can then boot. The monitors work fine through displayport when connected to the pc when it is on. The pc boots fine when the monitors are connected through dvi. I've also tried different combinations of monitors and cables and as soon as a monitor is connected through diaplayport it shows the error code.
The problem didn't happen before Monday but the monitors were new on Friday. I'm now stuck for idea for what could be at fault.
Specs:
I7 920 at stock speeds
Gigabyte ud5
12gb ocz memory
Corsair Hx620w
HIS 6950
7 HDD
2X BENQ BL2400PT monitors connected through displayport.
Thanks for your help.
