12 Attachment(s)
Ultimate LiquidPASS-EXATX
Hello,
Ultimate Liquid EXATX the inside and outside all was created by using aluminum material.
This width 600mm, height 300mm, height 120mm, using a large aluminum heatsink and CNC machining as a flow channel of liquid, natural cooling is the cooling.
Heatshink is a weight of 18kg, the total cooling capacity is about 2000W.
The width of the size of the finished case 465mm, height 680mm, depth is 600mm. Case weighs 50kg, and for tuning in to the top and left side acrylic window and the rear tray of the board that the board can be fitted to standard EXATX expansion slots are 10.
Board tray, using the Misumi aluminum rail to the rear detachable structure is easy to assemble and maintain.
In front of 10 hard disk rack and Koolance PMP-450S Reservoir with assembled two RP-450X2 liquid pumps and equipped with remote control for the VFD module focuses on the service was created.
Assembly and completion would take more time until the first stage is introduced case only.
Since this work Megatron 21 high-performance computing power, more practical and easy to organize the structure and to see the full purpose of implementing passive cooling structure was initially intended as a good representation of the concept and made the final result are satisfied.
