Problem With Indigo Xtreme Application
I know this may sound noob, but I've failed twice trying to install IX and want some help.
I'm running an i7 920 with an EK Supreme HF Full Gold waterblock. Yeah I know the IX will algamate with it but meh, I don't really plan on taking it off often.
Anyways, like I said earlier, I've tried two applications yet both failed with the same results. I'm probably overtightening, but I'm not sure how tight or how loose to make it, I always tighten my block all the way down so that the threads on the springs are touching.
http://img153.imageshack.us/img153/9...7002117.th.jpg
http://img687.imageshack.us/img687/1...002117a.th.jpg
I've also read this but I want to see other opinions so I can try them just in case this one doesn't work for me:
Originally Posted by
sRHunt3r
The best way for me is to load prime 95 with ht on and use half of the threads so on my 920 I ran 4 it does not load it 100% but heats it equally across the ihs and has less a likely hood of crashing during the reflow. That's just the way I have found to work best for me, other may have different opinions. As far as my waterblocks I tighten them down all the way down but loosen the bottom two a couple turns to help "direct" reflow across the whole chip and re-tighten them after the reflow. Again these are just the ways I have found to work best for me, others may have different methods.
