Need opinions and insight
Just ordered a bunch of new parts. Well I pretty much ordered all the internals for my Obsidian 800D.
i7-950
X58 ud5
6gb corsair dominator 2000mhz
2x evga 460 1gb
I already have a swiftech dual 120mm rad, apogee xt, and a mcp 350. I plan on getting a second pump, EKblocks motherboard block, and EK 460 full coverage blocks and a triple 120mm rad for the top of the obsidian. So I figured I was gonna have 2 seperate loops, with cpu and mobo on the dual 120mm rad and the two video cards on a triple 120mm rad.
The triple rad will be mounted at top of case with 6 fans, and I want to cut another hole in the bottom of the case and remove my bottom drive bay to mount my double rad with 4 fans.
Does this sound like the best way to have everything I want on water? Or should I do single loop with dual pump with a layout like pumps - tripleRad - cpu - motherboard - doubleRad - videocards - back to pump
Thanks!
