High Performance ITX Platform Review-Intel Core i5-655K Air Cooling to 5GHz
The normal image of ITX platform for users is hard to find in the market, price is high and old generation chipset.
Even it’s the NoteBook CPU socket or SO-DIMM design to make ITX platform price go even higher.
Intel launched 32nm Core i3/i5 CPU early this year and also launched H55/H57 chipset at the same time.
Also, many MB manufacturers launched LGA 1156 ITX MB. The price is lower than past ITX MB.
New spec ITX MB uses PC spec CPU and DDR3 that makes ITX product be more easy to use and cheaper.
http://img692.imageshack.us/img692/4994/i655k01.jpg
This review is to introduce the high performance ITX platform with latest products.
First of all, the CPU is Intel latest unlocked version, K series, Core i5 655K.
http://img59.imageshack.us/img59/4466/i655k02.jpg
Left side is product manual and right side is 655K CPU.
The special thing is 655K and 875K don’t bundle original cooler.
Intel suppose the unlocked version CPU users will choose better performance cooler.
http://img837.imageshack.us/img837/6749/i655k03.jpg
The clock is 3.2GHz supports Turbo Boost technology. The max speed is 3.46GHz.
Physical 2 Cores with Hyper-Threading can achieve 4 threads, called 2C/4T.
32nm manufacturing, L3 Cache is 4MB.
http://img692.imageshack.us/img692/9163/i655k04.jpg
CPU back design can see the version and different design.
The built-in GPU clock is 733Mhz.
http://img338.imageshack.us/img338/6614/i655k05.jpg
MB uses GIGABYTE H55N-USB3
http://img412.imageshack.us/img412/2066/i655k06.jpg
2oz cooper PCB, USB 3.0, 3X USB Power, and On/Off Charge are advantage features.
2 X DIMM DDR3 support 800/1066/1333/1600(OC), and maximum capacity is 8GB.
http://img718.imageshack.us/img718/1517/i655k07.jpg
1 X PCI-E X16 for user to install Low Profile VGA card.
Realtek ALC892 supports 7.1 channel and High Definition Audio technology.
http://img818.imageshack.us/img818/1205/i655k08.jpg
24 + 4-PIN power connector.
4X blue SATAII support by H55. It’s SATA2 and no RAID function.
http://img96.imageshack.us/img96/4369/i655k09.jpg
IO
1 X DVI-D
1 X HDMI
1 X D-SUB
2 X USB 2.0(Yellow)
2 X USB 3.0(Blue)
1 X eSATA/USB 2.0 combo (Yellow)
1 X S/PDIF fiber output
http://img259.imageshack.us/img259/1179/i655k10.jpg
