Pump/loop advice for dual loop 6 quad rads
Ok, so I have 6 quad Swiftechs going into my MM Ascension. I know overkill but i want a good overclock at 1000-1300 rpm on fans.
I just need to figure out how much pumping power I need.
2 loops seperate.
Loop 1 CPU EK - Mips corsair memory block > triple quad rads in pull ( maybe push/pull after)
Loop 2 ek X58 Sli le MB block and 1 ek 5870 Full cover block.
Now My question is Should I be fine with a Single d5/mcp655 With (koolance COV-RP450) per loop or do I need Dual D5's( Ek dual D5 top single loop) for each loop. Both have the Res's direct attached which I like. I tried sorting it out but the heat dump vs pressure etc I'm a little lost
