are the i7 950s now the way to go ..? ~ really another "is my spec ok" too thread.
Hi all,
I'm a long time lurker.
Now that the 950's have the price drop, is the 950 the way to go instead of buying a 930 .?
I'm on the verge of buying a new system. I want to reach 4.2Ghz at least and keep the system for a couple of years.
spec I want to get :
i7 930 or the 950 ( only £20 difference - worth having the extra multi's for that ? )
Asus P6X58D-E Intel X58
OCZ Reaper 6GB (3x2GB) DDR3 16000C9 2000MHz
Corsair Hydro H70
PALIT GTX 460 SONIC Platinum 1024MB ( will not go SLI )
Already have a corair 620HX
1. is the spec ok ...?
2. 930 or 950
I kinda think buying the 950 is like cheating as far as OC ' ing is concerned. - but it would ensure an easy overclock and prob 24/7 stable.
Any thoughts on getting the lesser known 950 ?
thanks in advance.
