Hi all!
Here is the new thread about my LN2 cooling products.
Please do not mess this one with offtopic comments etc. :up:
After I started to use LN2 I have been testing different kinds of LN2 cooling products. I found my own style and the things I like in CPU pots.
There was not that kind of pots available and I got opportunity to do my own designs, so I did my first sample in 2008. (http://www.xtremesystems.org/forums/...d.php?t=186131)
Then the next phase in 2009 was to produce improved models to get more power handling to the design.
Third beta phase was already very good and I got quite good results with it (http://www.xtremesystems.org/forums/...d.php?t=247009)
Then final phase was for fine tuning the design and do some compromises in production.
Then I got first Inflection point in to my hands.
The name Inflection point is taken from mathemathics and you can see the reason here: http://en.wikipedia.org/wiki/Inflection_point
This is how the product looks like:
http://sf3d.pp.fi/images/SF3D%20OC%2...Full%20set.jpg
http://sf3d.pp.fi/images/SF3D%20OC%2...%20%282%29.jpg
http://sf3d.pp.fi/images/SF3D%20OC%2...%20%283%29.jpg
http://sf3d.pp.fi/images/SF3D%20OC%2...%20%284%29.jpg
http://sf3d.pp.fi/images/SF3D%20OC%2...%20%285%29.jpg
http://sf3d.pp.fi/images/SF3D%20OC%2...%20%286%29.jpg
http://sf3d.pp.fi/images/SF3D%20OC%2...%20%288%29.jpg
http://sf3d.pp.fi/images/SF3D%20OC%2...revision/9.jpg
http://sf3d.pp.fi/images/SF3D%20OC%2...revision/2.jpg
http://sf3d.pp.fi/images/SF3D%20OC%2...revision/3.jpg
http://sf3d.pp.fi/images/SF3D%20OC%2...revision/4.jpg
I like when all things are exact and in good order. So CPU pot must behave very strictly and exactly how I like.
Inflection point is very fast and accurate in temperature adjustment in all temperature ranges from 0 to -196.
You first need to get used to it and then it can eat whatever you throw at it.
This design is suitable for all kind of CPU's with cold bug or not. There is no matter if it is AMD or Intel, new or old.
You can easily keep the temperature in very small frames during the heaviest possible load like Vantage CPU test or Wprime 1024M.
I have used many different CPU cooling devices and this is my approach to this matter. Some just like it very much and some very very much :D
Because of high demand there will be more products available later. I have good new ideas for GPU units too.
If you want to get Inflection point kit, just send me a PM :up:
Massman-
"I thoroughy tested this pot in Helsinki last weekend and I must say that I'm (again) impressed by how it handles the 980X!"
Predator-
" it's amazing! I love it! The best pot i owned ever so far!"
Slamms-
"After benching on this pot I may say that this is the best LN2 pot that I have seen."
elmor-
"Yes, it is ok" (If you can get this out of Jon, it must be good :D)
New contact information:
Send questions and requests to: SF3DOCsales@sci.fi
Thanks!
