Mountain Mods Ascension triple quad questions
Spec’ing my new box, I have a few questions. I have tried the search function, apologies in advance if I did a poor job of searching.
My last box (http://www.xtremesystems.org/forums/...5&postcount=25) needs replacing.
Starting notes: Low sound level is priority one. Normal state will be photo editing, www, visio, etc., I expect to be able to run 7v to my fans in this state.
The ability to selectively ramp up noise when I desire either normal performance (games) or high performance (benching) is desired.
So without further ado I am off to my 2nd WC build and the resultant questions for you guys.
Final system WC’ed components, i7-930 + 2x SLI 480 GTX
WC Components:
3x XSPC RX480 rads
Pumps: TBD (more detail to follow)
Res: TBD (Question below)
Case: MM Ascension: see pics for details of CYO
http://img844.imageshack.us/img844/2...nback75.th.jpg http://img839.imageshack.us/img839/6...front75.th.jpg
I will be removing the 5.25 cage on the front right and replacing with a blank to ensure clearance for the rads on the right side.
My gut tells me that I will end up with two loops, so to that end:
I have narrowed pumps down to ddc or d5 (aftermarket tops either way) .. Thoughts?
I may want to add a motherboard full-block (http://www.sidewindercomputers.com/ekevcl4ac.html) in the future.
With that in mind how would you split the rads? I am leaning toward assigning 2x 480 to SLI and the 1x 480 to CPU … If I were to add motherboard block later … which loop would be best to add it to?
Any advantage to a split path on the SLI loop (i.e., res-pump-T-480GTX-rad-T-res), so that 2nd SLI card doesn’t get heat wash from the 1st SLI card in the loop?
Any thoughts on Res model and location? (no 5.25 bays available)
Next, I am still struggling with airflow in the case .. and whether the RX480 likes air pushed or pulled if not sandwiched .. Thoughts?
I am leaning toward the evga 480gtx FTW (Single slot with full waterblock), other suggestions?
I can’t locate an example of a MM Ascension with triple quads … can you share any linkage on this?
Any experience using a BigNG with water temp probes for rad fan control?
TIA,
K-D
