Liquid Cooling a Silverstone Ft01
I do not have the need for the HDD cages in the front so those are already taken out which leaves me with a considerable amount of space in the front of the case. I am trying to water cool my 17 920 and also my gtx 470. I am not going to be doing much if any overclocking of my cpu. My main concern is the GPU. I am trying to keep the noise down as well as the temps.
I am looking for suggestions on the best setup and parts that you Xtreme Members :kissbutt: can think of for me to have an internal loop for my CPU and GPU.
Thanks in Advance.
Here are some pics of my case "not mine actually"
http://c2.api.ning.com/files/uuKFqds...eFT01Angle.jpg
http://www.maximumpc.com/files/u9069...ess01_Full.jpg
I do not have the drive cages in my PC. And I can find out another way to mount my HDD no problem. Also I will be using an External CD drive so that is not an issue either.
I will be using all stock 3/8in ID fittings (1/2in OD).
