Help needed for 1080P over HDMI
I really could use some help here so in advance I appreciate everyones input.
Here's the setup
Windows 7 64bit
2xATI 5850's 10.4 drivers
Acer H233H 23" has dvi/vga/hdmi inputs
Insignia 32" HDTV 1080P 60hz has vga/hdmi inputs amoung others
Problem
I can not for the life of me get the 32" hdtv to run at 1080P on HDMI. It will at most run 1080i 30hz. Over vga(dvi/vga splitter) it will run 1080p but the quality is less than great with a light rolling refresh lines.
What Ive done
HDMI at 1080P to Acer H233H works fine so I would conclude its not the video card not being capable, while having dvi/vga at 1080p to hdtv. Ive even done this http://www.sevenforums.com/tutorials...esh-rates.html and the monitor driver has changed from a "pnp generic" to something else random letters/numbers so I know the driver took. I tried forcing 1080P under CCC disabling hidden refresh rates under device properties. And a thousand combinations of doing each.
:shrug:Any thoughts?:shakes:
